[Prog Edit] Key
[MOD] key
Make sure you have a program called up in the [Prog Edit] screen
General Use Parameters: 123
Machine Parameters: 95148
PLC: 807667
how do i re-load the software to a heidenhain 426 controller? i am having problems with the controller ereasing the program as it is running the program. i was told to re-load the soft ware for this controller. can anyone help with this. Thanks km8137
Can anybody help me with the files from the PLC directory from a milling machine DMC70V with TNC426 -SOFTWARE 280474 15. HDD is broken and the data from this folder I could not recover them.
dear All
1- for seeing parameter on TNC 426 go to Edit mode ---select any program ---push MOD ---put 95148 then ENTER ---- for getting out just push END
2-for adjust Back Lash try to correct value on MP710 as MP 710.0 X axis MP 710.1 Y axis MP 710.2 Z axis ....up to rest axis
3-for HDD broken you need to have A- software 28047415 ( i can send you all soft you want ) ,..let me have your email , also you need same HDD as its easy to find in your local market this is easy procedure i send you step by step ,..just needs the machine parameter list or any back up you have ,..farzin.sharifi2012@gmail.com please send me any things you have ,..if you dont have i have same machine under my service i can prepare HDD to send you ,..its your Call
thanks
regards
F.Sharifi
Hello,
I need PLC software and MP for my deckel maho DMC70V milling maschine.
Heidenhain TNC 426/430.
NC Software 280476 18
Please can you send me?
Best regards
