Need Help! MAHO 600C - Philips 532 - spindle will not start after the tool change
Results 1 to 2 of 2
Thread: MAHO 600C - Philips 532 - spindle will not start after the tool change
    Mar 2017
    Bosnia And Herzegovina
    Default MAHO 600C - Philips 532 - spindle will not start after the tool change
    Hello Everyone,
    First of all I would like to apologize for my bad english ...
    I'm working on the MAHO 600C (Philips532) that has the following problem (bought with this problem):
    After automatic tool changes, the M5 function remains on ... When I write for example S100 M3, the M5 goes off and the M3 turns on, but the spindle does not rotate.... when I press CLEAR CONTROL or enter M30 command everything returns to normal ... until the next tool change...there is no error on the screen...
    In addition, I noticed that the programed spindle speed deviates from the one seen on the screen... for example if I set M3 S2000 on the screen it will write 1980 or similar....
    ...except the above mentioned machine works without any problems....but now it is impossible to create a program with multiple tool change until this malfunction is corrected...
    can anybody help me with this problem ?
    Mar 2017
    Default Re: MAHO 600C - Philips 532 - spindle will not start after the tool change
    anyone
    anyone
