Hi, I have recently bought a Maho MH600E and I am in the proses of retrofitting to linuxcnc. I haven’t power up the machine, I have strip the machine to inspect everything before move the axis. While cleaning I saw balls on the bottom of the machine, the match the groove off ball screw and the nut of the screw make noise while I turn by hand. I need to remove the ball screw and inspect it but I can’t remove the pulley from the end of ball screw. After removing the plate with the 6 screw, the pulley rotates freely. But there is not obvious way to continue.
