Need Help! Deckel Maho DMC 103V connect to PC
Results 1 to 6 of 6
Thread: Deckel Maho DMC 103V connect to PC
    Registered Cy4's Avatar
    May 2017
    Albania
    Question Deckel Maho DMC 103V connect to PC
    How can I connect my Deckel Maho DMC103V to PC/Laptop so I can transfer programs into a machine?
    I was looking around in the internet and there are a couple of ways in general for CNC machines, but I don't know which will work for my machine.
    Mar 2007
    Default Re: Deckel Maho DMC 103V connect to PC
    Quote Originally Posted by Cy4 View Post
    What control does your machine have? If it is a Siemens there is a network connection and 2 RS232 ports. You can use any of them to transfer programs. We use the network connection.
    If the control is a Heidenhain control there is network connections and RS232.
    May 2017
    Albania
    Yes and PC/Laptop dont have anymore RS232 ports what can i use to connect them ?
    Mar 2007
    If you want to use RS232 you will need a USB to RS232 converter cable.
    usb to rs-232 db9 serial converter | eBay
    I would just use the network connection and plug the 103 into your router. The network cable is inside the electrical cabinet on the left side. IF it's like my 103's.
    May 2017
    Albania
    Mar 2007
    Take a look at the picture it should help you locate the network cable.
    send me an email address and i'll send the picture to you full size
