Need Help! maho 500 e2 battery fault
Results 1 to 4 of 4
Thread: maho 500 e2 battery fault
    Apr 2017
    Macedonia, The Former Yugoslav Republic Of
    Default maho 500 e2 battery fault
    I just purchased maho 500 e2 but we discovered that battery had only 1,4 power. We changed the battery and after turning on we can not start the machine. It looks that there is No Power and on main screen there is Hardware Check memory mode 1 failed info. How to start the machine?
    Feb 2009
    Egypt
    Default Re: maho 500 e2 battery fault
    did it start before battery change
    Apr 2017
    I fixed the problem, battery is changed and found person who entered right parameters and its working.
    Feb 2009
    Egypt
    do you have the parameter as backup now or could you chare the information of the person who helped you out. I still need parameters for a 600e /e2 analoge spindledrive with toolchanger. I tried a lot of parameters but still getting problems ..
    my e mail is kabdelwahid @ gmail
