Deckel Dialog11 "interpreter" dialog4
Results 1 to 1 of 1
Thread: Deckel Dialog11 "interpreter" dialog4
    Registered cadcam2008's Avatar
    Mar 2014
    Default Deckel Dialog11 "interpreter" dialog4
    Hello, I have old program for NC Dialog4 (and I have also a CAM with postprocessor for dialog4) and I want use them with a Deckel FP4A -Dialog11
    I read on dialog11 handbook that exist an "interpreter" with latest sw cnc version and so it can work with oldest program for dialog4 but I don't understand how can I enable it.
    I tried to modify the old programs changing the header (loader)
    example:
    % 100104 (M-D11-N - outer contour)
    modifying it insert D4
    % 100104 (M-D4-N - outer contour)
    and then transmit by RS232 to Dialog11 but it does not work, the program loaded on the NC seems empty
    Also transmit original program in dialog4 format header doesn't work
    How can I enable the "interpreter" for old programs?
    THANKS
    cadcam2008
    Sep 2010
    Magyarország
    Default Re: Deckel Dialog11 "interpreter" dialog4
    %314 ( -D11-000158- - -3D-30FOK)
    05AA
    %314*T ( - -000088- - - )
    T1 I/M:M R12.31 L-76.77 FE800 FZ60 S1600
    T2 I/M:M R5.94 L-55.21 FE300 FZ300 S1600
    134D
    %314*% ( -D11-0000D0- - -3D-30FOK)
    N10 G17 T1 M62 G64 M6
    N20 G0 X29.5 Y90 M3
    N30 G0 Z0.3
    N40 G41 X16.8268 Y61 G1
    N50 G1 Y-1
    N60 G40
    N70 G0 Z35
    N80 G55 ZI-0.15 XI0.0866
    N90 L120 N20 N80
    N100 G0 Z200 M30
    23B3
    %1
    0000
    %1*%
    N2 G17 T1 M6;M62 G64 [ T3 -D16.00 - SAROKRÁDIUSZ: R8.00 ]
    N990305 G0 Z100
    N990306 M5
    N990307 M30
