Hello I wish my first post was a bit happier but unfortunatly not.
Im having problems milling a hexagonal on a Doosan Puma 300MS. I cant fint any problems in the programming or coordinates but it still removes more material on one side than the other. I've tried changing things around in the offset,geometry,wear and work registry but nothing changes other than the diameter of the part. We have crashed into to main spindle a couple of times but we recently had a repairguy here.
This is the first part of the milling process:
The hexagon is supposed to be 62mm across.
G98G97S2500F500M33
G28H0
G0X105C0Z5
G1Z-41M08
N200G12.1
N205G1G41X83.694C10.481
N210X35.796C-31
N220X-35.796C-31
N225X-71.591C0
N230X-35.796C31
N235X35.796C31
N240X83.694C-10.481
N241G40X105
N242G13.1
It's like when you are milling in a mill but you have set your x-zero or y-zero wrong so it's not in the middle but a bit offcenter.
LinkBack URL
About LinkBacks
