Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 01-30-2010, 12:37 AM
fadalserviceguy is on a distinguished road
fadaserviceguy
A FRIEND HAS A PUMA LATH WITH A FANUC 10T - HE TELLS ME THE PROBLEM STARTED OUT THAT HE COULD NOT TRANFER CODE VIA HIS RS232 PORT - HIS ELECTRICIAN LOOKED AT IT AND PULLED CO4 CONNECTOR OFF THE I/O BOARD WHILE IT WAS POWERED UP - NOW THE CONTROL BOOTS UP AND IT COMES OUT OF E-STOP ALSO THE HYD COME ON ALONG WITH THE COOLANT IMMEADITLY - THEN THE CONTROL APPEARS TO BE LOCKED UP - IT DOES NOT RESPOND TO ANY KEYS OR MODE SWITCHS - I LOOKED AT PMCLAD ALSO IT DOES NO SEE ANY INPUT SWITCHES CHANGES - HE HAS ALLREADY SWAPPED THE CONTROL KEYBOARD INTERFACE BOARDS WITH NO RESULTS -WILL A I/O BOARD CAUSE THIS - HELP
DAVE
Old 01-30-2010, 11:37 AM
Al_The_Man's Avatar
There are fuses for the 24vdc on the I/O boards that should be checked first.
Or if the operator panel P.B's or switches do not register on the I/O then you may have lost a 24vdc supply.
Old 01-31-2010, 02:06 AM
THANKS FOR THE INFO AL - THE FACT THAT THE PMCLAD SCREEN SHOWS NO I/O CHANGES IS INTERESTING - BUT I DID NOT SEE ANY FUSES ON THAT BOARD - IS THERE SPICIFIC TEST POINT TO VEIRFY THAT THE 24 VDC IS PRESENT
THANKS
DAVE
