| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
I need to put 3 holes radially on a 12" diameter part 120 degrees apart from each other. They are not inline with anything so I can start first hole anywhere. The drilled holes are thru to center bore and are 3/4" diameter. They have a 2inch deep counterbore in each hole that is 1.5" diameter. Here is my problem..... I have a Daewoo/Doosan Puma 700LM. I have and use the live tooling options quite a bit so I know how to drill the 3/4" diameter holes without problem. I do not however know how I can helical mill (circular interpolate) the counterbores. I do not have a Y-axis option with this machine which hence raises my dillema. Is there another way? Any help would be appreciated to point me in the right direction. Any examples would be helpful as well. DWG SPECS: 12.500 DIA. O.D OF PART HOLES ARE 5" IN ON Z FROM FACE OF PART 3/4 DIA THRU HOLES INTO A 10" BORE 1.5" DIA. COUNTERBORES THAT ARE 2" DEEP IN EACH HOLE HOLES ARE 120 DEGREES APART(1ST HOLE STARTS ANYWHERE) I just don't believe that it would be possible to do without the Y-axis. I could see it being done on the face of the part but not on the cylinder or radially. Maybe I'm tupid..... Thanks bdyenter Last edited by bdyenter; 01-20-2010 at 11:08 PM. |
| I changed the scenario a bit today and thought about similar situation but really I guess no different. I was thinking about a bolt circle pattern around this 3/4 radial hole. How in the world would I be able to approach that with out a Y-axis. Sure I can move over on Z axis but how would I move up or down from that 3/4 hole without moving the C-axis. This is why I think I anwsered my own question... just had to think tad more I guess. Bummer for me I guess. |
| Need Help!- Doosan/Daewoo 700LM Post | CMK1 | EdgeCam | 0 | 08-30-2009 10:25 AM |
| Problem- X3 - threadmill on live tool | cnc-king | Mastercam | 3 | 10-13-2008 10:55 AM |
| Puma2500Y live tool | phx | Daewoo/Doosan | 5 | 07-09-2008 12:42 PM |
| ANy one with a Puma 300M with live tooling? | M-man | Daewoo/Doosan | 8 | 06-27-2006 01:25 PM |
| PUMA 12LB - Fanuc 0T - Radial Socket | ap-machine | Daewoo/Doosan | 1 | 09-21-2005 03:59 AM |
