| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
| Hi, I have a Doosan 6030 Revo Mecatec mill with a Fanuc 0m control. I have a project that requires broaching a slot in the cylinder. Does anyone know how to get around the safety in the machine that prevents the axis from moving in Feed mode with the spindle off? ![]() I am trying to move the Z and X axis in Feedrate mode with the spindle locked in the orient position...Built in safety prevents me from doing this... Thanks, Richard Last edited by macrob5482; 01-04-2010 at 04:01 PM. Reason: Better explanation needed... |
Tried that command...In our machine, M84 relates to the ATC...M59 needs to be use, then it wants to check for a pot down position. I've had to do this on other machines and it was a change in one of the parameters, but I can't find my notes to apply it on this machine.... Anyone else have any ideas on how I can do this? It's light broaching, so I figured if I can set the tool up, orient the spindle and set the tool manually so it's in the right direction I could get it done without removing the part and doing it as a secondary op....... Thanks! |
| Try M184 = Axis Moving Valid when Spindle Stop M185 = Axis Moving Invalid when Spindle Stop
__________________ *********************************************************** *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~* *********************************************************** *__________If you feel inclined to pay for the support you receive__________* *_______Please give to charity http://www.oxfam.org/en/getinvolved_______* *********************************************************** |
Im fairly certain you cannot G00 if you cannot G01
| Need Help!- R2E4 Boss 9 X Axis locked up | ironworksdesign | Bridgeport and Hardinge Mills | 6 | 06-29-2009 07:54 AM |
| Feed rates / spindle speeds for HF spindle | yngndrw | General Metal Working Machines | 2 | 03-21-2009 11:46 AM |
| Need Help!- Y axis moving without being programmed HMB-1 | carbidecraters | HURCO | 1 | 06-22-2008 01:51 PM |
| Need Help!- Series I, Z axis locked in up position | marvfrankel | Bridgeport and Hardinge Mills | 2 | 04-30-2008 04:30 AM |
| Axis are not moving | Reef Guy | Mach Software (ArtSoft software) | 4 | 09-13-2006 09:42 PM |
