Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 12-03-2009, 08:10 PM
driftbuster50 is on a distinguished road
Smile g code help puma 160
I have a Daewoo Puma 160 with a Fanuc I series control. I am setting up a prodution bar pull job, my question is. Can I move the gang style turret with a slow feedrate without the spindle turning? I would like to do this for use with the barpuller. The only move that I know of is a G00 move and it is to fast. Also, is there a command to bypass the chuck open close status so I can use g code to open then close the chuck in my program. Every time I try to close the chuck in the middle of the program I get a chuck unclamped status alarm. I would appreciate any feedback.
Old 12-04-2009, 01:28 AM
dcoupar's Avatar
Use G98 (Feed Per Minute) with G01.
G01 G98 W-2. F50. will feed -2.0 in Z at 50 IPM.
Be sure to program G97 when you're ready to start feeding in IPR again.
M31 (INTERLOCK BYPASS FOR MAIN SPINDLE) - must be programmed in a block by itself.
Old 12-04-2009, 03:57 PM
this worked great!!!!!! thanks for the help.
Puma 2500lsy Kingz Daewoo/Doosan 47 02-25-2011 10:37 PM
Need Help!- PUMA 240 M turnn Daewoo/Doosan 2 12-09-2009 12:36 PM
NEED HELP WITH PUMA 200 CNCBEN Daewoo/Doosan 2 09-16-2009 11:52 AM
Newbie- Puma 12L Lathe ccrow2000 Daewoo/Doosan 0 01-13-2009 02:28 PM
Puma M-man Daewoo/Doosan 1 05-13-2008 10:25 PM
