Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 12-02-2009, 07:17 AM
SINUMERIKO's Avatar
SINUMERIKO is on a distinguished road
Daewoo Lynx 210 turret
Hello,
I’ve been trying to fix this hydraulic turret for about a week or so after an operator had it crashed. It unclamps ok in all 12 stations, turns both sides as commanded but almost half of the times it skips the exact point of clamping back and after 2 or 3 seconds being stopped halfway between stations the alarm pops up. Looks to me like it is not reducing the turning speed at the appropriate moment and it skips the right position due to inertia. I’ve disassembled the whole turret, even the index motor has been taken apart without finding the cause or anything wrong. The solenoid valves and their coils are ok; I’ve changed the fwd, rev, unclamp and speed reduction relays already. I tested the encoder at bench and at PCM DGN status, I have also checked the clamp sensor. The turret can sometimes complete the 1 to 12 changes, one by one, but only in forward direction, if I go from say 10 to 9 it immediately fails. I’ve not found excessive wear at the main shaft or anywhere else, the lock pins at the main tool holder front plate were replaced after the crash. Everything is chip free and lubricated; the main hydraulic pressure is set at 600 psi as the manual says, the solenoid valve coils are 40 ohms.
What else should I check? ...Any and all the help is greatly appreciated.
Thanks.
Old 12-02-2009, 09:35 AM
SINUMERIKO's Avatar
Some pictures.
ID:	94387   Click image for larger version
ID:	94388   Click image for larger version
ID:	94389   Click image for larger version
Old 12-03-2009, 01:41 AM
SINUMERIKO's Avatar
More info on same issue
Today I tested the turret without the disc, just the main shaft without the heavy load, I only installed onto the shaft the spacer, the flange, the locking element and the lock nut so that the shaft could move back and forward when clamping/unclamping. The result was fine, in this way the turret changes perfectly all stations, both directions.... I just can´t figure out how the load affects its functions so bad, seems like if any of these were happening:
a)With the disc mounted, the hydraulic system is not "braking" or reducing the speed as needed when the exact point of entry is approaching.
b)The mechanical play that the shaft could have is somehow amplified by the weight of the turret disc and shows up only when this disc is mounted on the shaft.
Any ideas yet...somebody?
Old 12-03-2009, 08:03 PM
SINUMERIKO's Avatar
Video
I've added a video showing this last test:
Any ideas, anybody?
Old 12-05-2009, 07:54 AM
meelian is on a distinguished road
hi
what's problem in your lathe machine? i read the description of the machine turret ,but dont understand the issue,please give me a copy of detailed file.
Old 12-05-2009, 08:01 AM
hi
Originally Posted by SINUMERIKO View Post
Hello,
Thanks.
ok,u say your turret can forward turn,but cant reverse trun,can u tell the alarm from the machine?
Old 12-05-2009, 08:53 AM
SINUMERIKO's Avatar
Trouble description
Meelian,
The problem with the turret is that it won't always clamp, almost half of the times it will go beyond the exact point of clamping, the alarm is 2047.
NOTE: This only happens with the turret disc mounted on, if I try it without the disc, as in the video, it won't ever fail.
Thanks.
Old 12-05-2009, 09:14 AM
SINUMERIKO's Avatar
NOP index motor
Last night I got the attached information from the index motor manufacturer's site. I strongly believe that this turret's problem happens because it is unable to (hydraulically) brake with enough power as explained on their page #8 of this catalog, just follow the ball in the graphics, 1 thru 8.
That would explain why it brakes OK without the disc.
Please take a look.
Old 12-19-2009, 08:59 PM
SINUMERIKO's Avatar
SOLVED: Daewoo Lynx 210A turret issue
The turret's main shaft received a hard chroming process on its teeth, where it and the large gear work together, and later another process of grinding those teeth to bring them back to original dimensions, all this to eliminate the wear that was causing the mechanical play in the turret assembly.
I also performed some service on the machine´s hydraulic system, including the Japanese NOP index motor "O" rings replacement and a full service to the hyd unit, along with the encoder sync and the clamp sensor check. Once assembled, I tested the turret randomly, about 500 times, with balanced/unbalanced load, it NEVER failed.
I uploaded a new video with the final tests, I hope all this can be used as reference/help in the future for somebody out there.
Video:
DAEWOO LYNX 220LM jackson Daewoo/Doosan 17 08-22-2011 11:18 PM
Daewoo Lynx Draw tube mekp21 Daewoo/Doosan 6 05-28-2008 08:27 AM
Daewoo Lynx 200b atscnc Daewoo/Doosan 1 03-23-2008 01:28 PM
Unloading 2002 Daewoo Lynx 210LC? Chuck Reamer Daewoo/Doosan 3 01-06-2008 04:39 AM
DaeWoo Lynx 200 GL fjd Daewoo/Doosan 5 10-29-2005 10:43 PM
