Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 10-28-2009, 03:00 PM
riverking is on a distinguished road
Thumbs up C axis direction
Hi, we have just got a puma 200m which is ok, we also have 2 puma 2000sy , the problem is the direction of the c axis is different , is there any way to make them the same? when you use the mpg to turn the c asis it goes the wrong way, also if you run a prog from the 2000sy the H direction is wrong and the part is scrap, any help would be great
riverking
Old 12-08-2009, 07:38 PM
CHAD LAWSON is on a distinguished road
you need to really read through your programming manual on these machines prior to running a main spindle and a sub spindle. the doosan allows you to dictate with mcodes weather the main spindle or sub spindle is head one. if you think about this you reverse everything when you switch main spindle locations. i can not think of the m codes off the top of my head but i had to help my programmer get through this using the ladder to understand exactly what they were doing. i want to say look at the m68 and m69 but i may be wrong. problems also arise when sinking the two spindles if this is occuring. was this machine a turn key package because often unexperienced programmers can get this messed up. we bought a turn key twin turret twin spindle machine and when my programmer noticed in the program they were commanding a m3 and m4 for proper main spindle rotation at different points of the program and yet they always turned the proper direction. he was quite confused so once i explained how it worked to him he wrote the entire program over basing all spindle directions using the main spindle as head one. i don't know the advantage to being able to do this abd doosan is the only machine i have seen with this feature.
x axis only runs in one direction PLEASE HELP m8kingit DIY-CNC Router Table Machines 3 10-25-2009 12:53 PM
x axis ( direction change ) musnar HURCO 3 10-15-2009 03:42 AM
2.5 Axis Direction Control ee_cnc LinuxCNC (formerly EMC2) 2 11-21-2007 09:42 AM
Need Direction on 4th 5th? axis program Cappy GibbsCAM 3 04-20-2007 08:20 PM
A axis direction change? nervis1 Fadal 18 10-27-2006 11:49 AM
