Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 10-19-2009, 12:45 PM
Bigbill is on a distinguished road
cutter comp on c-axis
Hi
I have a puma 230m with Fanuc 21i tb control. I am cutting some lots across the end face of a turned tube(looks like a castle top). Does anyone know how the operator offsets to compensate for the slot width. I am cutting the slot on both sides so we can make it bigger or smaller. I think he has to put a value in the "R" on his offsets but is the "T" used and if so how is it used? We can't find it in the manual as it relates to c-axis. Do I need to program any specific code?
BigBill
Old 10-19-2009, 03:11 PM
dcoupar's Avatar
Are you using G12.1 (Polar Coordinate Interpolation)? If so, you can use G41/G42. Here's a document from Kaspar @ Doosan that may help.
Old 10-20-2009, 01:07 AM
von007 is on a distinguished road
god like
Casper is a god!!
3-axis cutter comp? ghyman G-Code Programing 15 06-29-2009 12:54 AM
Cutter Comp. Bob Z1 SmartCAM 2 05-28-2009 11:21 AM
Cutter comp on an id hole< cutter diam.?? PaintItBlue Haas Mills 5 05-05-2008 07:30 PM
Cutter Comp? donl517 Fadal 5 07-03-2007 09:36 AM
Not using cutter comp HuFlungDung OneCNC 6 05-28-2003 05:59 AM
