| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
After trying for way too long I found out that the Puma230MSB can't thread mill along the Z axis because it has no Y axis. Trying to use g12.1 gives me a plane selection error. There has to be a way to get around this because I need to thread soft nylon and single pointing only makes a mess of it. I'm using a Z live tool drive and can easily take the cut in one pass but how do I calculate the feed rate for 18TPI? |
| Puma 230MSB is a lathe with C-axis, right ? you don't need a Y - bring the tool down to clearance on Ø - start sub-spindle - feed cutter to Ø - feed ( C-axis 360° CW ) & ( Z- axis 1 pitch ) in 1 block - feed cutter out, & done ie. 150mm thread x 3mm pitch x 10mm deep Code: G144 ( eg. code for milling mode) G0 X100. Z0. C0. Z-7. G101 X75. F100. G102 Z-10. C360. G101 X100. G0 Z0. G145 ( eg. code for turn mode ) |
Heres one I did last week with no Y axis just used C X Z axis and live tooling N60T0808(18 PITCH N.P.T. THREAD MILL) M24 G54.1P1 S2315M33 G0X0Z.1C0M8 G98 G1Z-.6F50. X.168Z-.5725H180.F7000. Z-.5169H360. X0Z-.4891H180. G0Z5.M9 |
| thread milling | fourperf | Fadal | 13 | 03-10-2008 08:14 PM |
| Thread milling | TT350 | Tormach PCNC | 7 | 11-30-2007 10:01 PM |
| 0M-Thread milling? | mikul | Fanuc | 1 | 12-06-2006 12:56 AM |
| Thread Milling 3/8-18 NPT | shawn | G-Code Programing | 13 | 08-26-2006 09:24 AM |
| thread milling | DavidC1949 | G-Code Programing | 2 | 03-30-2006 01:27 PM |
