Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 09-14-2009, 12:09 PM
Mark18969 is on a distinguished road
Daewoo 4020 Mill Spindle Belt Breaking
I have a Daewoo SMV 4020 That keeps breaking the spindle belt. We purchased this machine in the fall of 2005 new, and have replaced the belt in 8/07 and 12/08. It just broke again. There is only one manufacturer for this belt, it is a Goodyear W-800. It is a 12,000 RPM spindle, and we have only ever run aluminum on this machine. No spindle loads.
It is a wide timing belt, but instead of having straight grooves, they are VEE shaped and the belt only fits in one way.
Anyone else having belt breakage problems?
Old 09-16-2009, 11:47 AM
resuengineering's Avatar
resuengineering is on a distinguished road
leave the belt a bit more slack, propebly over streched/tightend
or the pulley's arn't alinged ok.
Old 09-16-2009, 11:56 AM
Just got feedback form Goodyear who makes the belt. It seems the instructions for figuring out the belt tension were incorrect for this application.
It needs to be much tighter. Glad we contacted Goodyear’s tech department after Daewoo had no answers. After 3 belts at $600.00 plus per install.
Old 09-16-2009, 12:06 PM
ok, good to know, normally you see overtightent a belts
cause to generate a lot of heat and wear.
Tags
doosan, spindle belt breaking, spindle belt problems
HELP ASAP with Fadal 4020 Spindle TurboBlazerX Fadal 11 04-21-2009 10:15 AM
spindle will not stop fadal 4020 choppermex Fadal 3 05-21-2007 11:26 AM
VF-2 (15,000rpm) SPINDLE BREAKING PROBLEM boodoowaa Haas Mills 18 02-13-2007 02:08 PM
4020 spindle rebuild Roy's cnc Fadal 33 06-13-2006 05:21 PM
Spindle lube on 4020 Fudd Fadal 4 01-22-2006 12:31 PM
