Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
  #13   Ban this user!
Old 09-23-2009, 08:06 PM
andyb4 is on a distinguished road
Had good luck today. Fixed tool change arm position switch, to get cycle start string to work. Wouldn't read any code, had to fix lub level switch. Got M and S codes to work. Used M11 to unclamp table, it now moves. M11 B0;M10, had alarm PS076, no macro program. Set Parameter 7000 bit #2 so aux axis not to call custom macro. Reads code but alarm not referenced. Now changing parameter 1815 to teach B axis home position. Haven't mastered the order yet, only so much time, but it is looking good. Still seems to hang up on basic move, G91G1F100.x-1.; Reads but not execute. Let you know how things are after B is referenced. Then on to the macros for the pallet and tool changes. Looking good though. Thanks
  #14   Ban this user!
Old 09-25-2009, 08:48 PM
Looks like all is working except that the B axis does not unclamp automatically. Must be missing something in the settings. The axis only feed when the spindle is running, new to me but makes sense. M34 can be used to bypass the feed interlock until reset is used. Onto the tool and pallet changers next.
  #15   Ban this user!
Old 09-26-2009, 04:01 AM
meelian is on a distinguished road
hi
what about your machine now? can u tell me about your machine's information?
  #16   Ban this user!
Old 09-30-2009, 11:12 AM
Still having a problem with B axis unclamping automatically. I haven't got the pallet to unclamp at this point either. It does work by changing the keep relay for the pallet clamp. Have gotten the macro programs in the machine for the pallet and tool change. They are hanging up as well. Doesn't start O9002 for pallet change by M60 or running Program O9002 from memory. It will run a simple program from memory however. (O1000) I will try and scan and post more info about machine. Thanks
  #17   Ban this user!
Old 10-01-2009, 06:28 PM
Have the B axis working properly now. All seems to be down to the macro programs. Thank you guys for all your help. Think it is just a matter of time now. Thanks
Lost parameters darrylh Fanuc 15 06-09-2010 02:02 PM
Need Help!- Parameters lost padams Want To Buy...Need help! 1 05-17-2010 08:09 PM
Daewoo Puma10S FS-0TB Parameters needed hrh Fanuc 0 01-15-2009 11:03 PM
Problem- Lost parameters alfonsosti Okuma 7 12-16-2008 08:40 AM
OKK Parameters lost!!!! Fidelity_Mold General Metal Working Machines 2 08-01-2007 02:20 PM
