Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 08-24-2009, 03:52 AM
davehrdy0909 is on a distinguished road
Unhappy doosan v550/fanuc 18t
I had the machine fault out on a 424 alarm. It had just finished the part and should have just been starting to rapid out. Could not reset without turning the power off. Now that i did that, All the lights are flashing on and off and I am getting a 400 code?. It is on the main program page flashing between the left and right spindle programs. We have powered it down several time to try to reset the fault with no luck. Any help would be greatly appreciated!
Old 08-24-2009, 06:14 AM
ccs007 is on a distinguished road
AL424 is servo alarm, go and see what is the alarm code shown on servo amplifier.
Old 08-24-2009, 09:09 AM
cncrepair is on a distinguished road
Did you see any alarms on your servo drive displays?
Usually the 400 series alarms denote the RAM parity error, but the 424 is an alarm on the 2nd servo in your system (Y-Axis on mill and Z-Axis on a lathe).
The Fanuc book #B65165E will show the alarms and their remedies for you.
Marko
marko@fixmycnc.com
Old 08-24-2009, 12:13 PM
Macdan is on a distinguished road
Any 4XX alarm means Servo Alarm. You should take a look to the ServoAmplifier display code to known the fault origen.
Old 08-24-2009, 04:10 PM
Leksvil is on a distinguished road
The 424 alarm is an unlisted alarm, but the 400 is not. basically you have a overload condition on one of your axis.
SERVO ALARM: n-TH AXIS OVERLOAD ( n is the axis )
check diag. 201 bit 7 the left most digit.
0 = motor overload
1 = servo amp. overload.
check for swarf build up, damaged axis guards and slide lube unit all could contribute to the above alarm. Either way, you will probably need your local machine tool engineer to have a look.
Well I've never seen it do that before!!!!!!!
Old 08-24-2009, 08:38 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Wot, they said ......
Fanuc 18 alpha
400 = Over heat alarm on servo module/servo motor or faulty fan on servo module/servo motor
B-65165E/02 Page 105
424 is not listed for alpha motor or any other
best to check the codes on the servo modules in the electrical cabinet !
Old 08-24-2009, 09:55 PM
Thamks guys for te info. Now atleast i have an idea where to start!
Old 08-25-2009, 11:08 PM
cncmaintenance's Avatar
cncmaintenance is on a distinguished road
There are small fans on the heat sinks of each drive modules that commonly acumillate dirt or residues from the surrounding environment. Usually can be cleaned to restore function.
Old 10-09-2009, 09:16 AM
von007 is on a distinguished road
400!
Ok lets ask the obvious as 400's are kind of umbrella like.
What alarm are u getting on the drive! Thats the real story. Remember when it comes to trouble shooting 1st rule of diagnostics is ask who is your god? in this case the crt alarm is generated from the drive thus the drive is god and all else is mute. Find out the alarm on drive then proceed.
von007
Chips AHOY
Need Help!- Doosan S 280 Fanuc 9000 parameter for M06, M07 Donnie57 Daewoo/Doosan 5 03-27-2009 01:54 AM
Need Help!- Doosan DVC 500 Jay H Daewoo/Doosan 0 10-03-2008 10:32 AM
Need Help!- Doosan s 280 parameters dovi Daewoo/Doosan 0 07-06-2008 05:41 AM
doosan vtl rags Daewoo/Doosan 7 06-22-2008 03:05 PM
doosan fanuc 18t turret julio_gyn Fanuc 3 05-19-2008 01:43 PM
