Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 07-12-2009, 01:16 AM
MadMax is on a distinguished road
plugging/unplugging RS232 input cord with power on. Is this ok?
I remember back in the day, it was a bad idea to plug in or unplug serial peripherals with things powered on. I think it was because of PC driver issues which wouldn't load right on power on.
Is it a problem to connect or disconnect a data connection to a Fanuc 18T while it's powered on?
Old 07-12-2009, 03:17 AM
dcoupar's Avatar
I've done it at least a couple hundred times without a problem, but maybe I've just been lucky. Fanuc advises to turn power off before plugging/unplugging the RS232 cable.
Old 07-12-2009, 09:55 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
I've never had a problem
Old 07-15-2009, 08:46 AM
meelian is on a distinguished road
perhaps
perhaps,Fanuc's main board was injured. when your machine power on
, the alarm dispaly what it is . my msn: jacky.lian@hotmail.com
Old 07-15-2009, 09:40 AM
Boots is on a distinguished road
when hooking up our laptop to the machines we do not power down, plug it in, then power back up. You are talking about the printer and printer drivers installed correctly. RS232 for communication to CNC is fine. Just don't boot your comm software untill the connection is made otherwise the software will not see it and you will get an error.
We all live in Tents! Some live in content others live in discontent.
Old 07-16-2009, 01:18 AM
Thanks for your replies. My lathe is finally talking and the parameters are backed up *whew*.
Need Help!- Powermax 1000 - do I really need to replace the power cord for single phase? MoparJon CNC Plasma and Waterjet Machines 6 10-22-2008 05:13 PM
rubber cord for vacuum table diecutter DIY-CNC Router Table Machines 3 02-17-2008 05:19 PM
program input/output with RS232 port on Mitsubishi 50L Chuck Reamer Mazak, Mitsubishi, Mazatrol 3 02-04-2008 03:56 PM
Interact 1 Power Input Question rkdygert Bridgeport and Hardinge Mills 4 09-06-2006 01:41 PM
Extension Cord dneisler Welding, Brazing, Soldering, Sealing 4 01-13-2006 08:29 PM
