| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
I've noticed a puddle developing at the bottom of my lathe and I realized it was hydraulic fluid. I found three leaks coming out the bottom of my drawbar actuator. The big obvious one was caused by a heavy leak around the threaded outlet elbow. That was an easy fix, but I've noticed two other leaks. One is out a side hole near the rear of the actuator. This one is a steady light flow. The other is a drip (1 drop every second @ 200psi) accumulating at the bottom of the fan cover at the front of the actuator. I don't see any thread in the two holes drilled at the back of the actuator so I don't think I'm missing a plug. I've stopped running the spindle because I'm worried about something flying out of the chuck. Has anyone seen this kind of leak before? I'm running a Daewoo MSA200 Puma with a 6" main spindle. |
Sounds like your actuator is leaking and needs new seals or bearings. I just had mine rebuilt for $1800.00 but that included new bearings also. I couldn't take the leaking anymore. After I reinstalled it you wouldn't believe how much smoother the spindle ran. Bad Dog |
| Yeah, it was a mess. Turns out that one of the orings in it was damaged. Looks like a previous owner attempted service which damaged the oring during reassembly. Reassembling the actuator was very difficult. Alignment is a bugger and in the end the entire dingus had to be replaced altogether due to a flange damaged during reassembly. |
| troubleshoot glentek 4th axis board | timo2le | Fadal | 3 | 02-27-2009 06:20 PM |
| No X axis movement- how to troubleshoot? | WayneC | Machines running Mach Software | 2 | 02-16-2009 05:54 PM |
| Need Help!- Improve/Troubleshoot Parallel Port | blue_steel | General Electronics Discussion | 2 | 12-13-2008 08:39 PM |
| Need Help!- Help troubleshoot Lincoln SA 200 | aawelderswife | Welding, Brazing, Soldering, Sealing | 2 | 07-18-2008 10:08 PM |
| Troubleshoot DNC | phoodieman | General Metal Working Machines | 6 | 09-21-2006 02:44 PM |
