| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
I just picked up a Daewoo MSA 200 PUMA which is missing it's tool presetter as well as it's parts catcher. A previous owner took it off to rebuild another Daewoo machine which needed those parts. Can anyone recommend a good parts supplier for Daewoo lathes? |
| I would suggest you contact your local Doosan dealer as you stated you are in Canada please view this site DOOSAN WEBSITE This will allow you to select your State etc and will give you details of your nearest dealer Last edited by MysticMonkey; 06-14-2009 at 09:48 PM. Reason: wrong website |
| Hi Max . Probably I can advice you , I had solve the problem you had facing. The problem lies at the interface board . You may find it at the electrical cabinet . If you could give me the model or code ..I could supply it to you . By the way im in singapore ..and im new here . Ciao sam |
| Hi Sam, Thanks for your reply. I've managed to find a parts catcher, but I think I need to get a tech in to see if my machine is even configured for a toolsetter. I note that the Q-setter switches aren't even there. There are plastic plugs where the q-setter switches would be so I think my machine never had one. Even if I find a q-setter I think I'll have to figure out how to set the parameters to make it available. |
I assume your machine has an arm for the tool eye,,, pull it down, switch into jog and see if the control shifts in to pre-setter mode. Are there wires going to the tool eye ? (through the shaft) try using m code to bring it down try m80 or 81 look in your manual. an aftermarket brand is going to cost you $375 for a new one. good luck Bad Dog |
| Need Help!- Daewoo with Mitsubishi controller tool setter question | cruizer67 | Daewoo/Doosan | 7 | 10-22-2011 02:24 PM |
| daewoo puma 200c tool setter | spirowski | Daewoo/Doosan | 4 | 02-10-2009 11:04 PM |
| Need Help!- Tool Setter Macro for M-V60C and Metrol Setter | mitshack | Mazak, Mitsubishi, Mazatrol | 0 | 10-06-2008 09:39 AM |
| Need Help!- Tool setter macro for M-V60C and Metrol setter | mitshack | General CNC (Mill and Lathe) Control Software (NC) | 0 | 10-06-2008 09:38 AM |
| Tool holders for Daewoo lathe turret? | Chuck Reamer | CNC Tooling | 1 | 01-01-2008 07:14 AM |
