| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
Anyone here running a Doosan Infracore Lynx 220LM? I am looking at my first CNC lathe. I got a little demo of this machine last week and wondered what you guys thought of it. Good Points, Bad Points, Options etc.? The C Axis live tooling really looked nice and the machine comes stock with a variety of tool holders including 2 pcs. Eppinger Preci-Flex ready X Axis (Straight) milling heads and 1 pc Eppinger Preci-Flex Z axis (angular) milling head. Any input would be appreciated. Thanks, John |
| Nice machine, I have ran a couple of them. Keep in mind, the live tooling is only 5 Hp, so don't expect it to behave like a machining center in regards to milling. The Eppinger tooling is sweet, and the PreciFlex attachments even sweeter. I believe that machine has half indexing (24 position indexing), which is a nice feature to allow you to put 24 turning tools on the turret if you wanted to. Make certain any of your future work doesn't require a Y axis to come off center, as you won't be able to do so with the 220LM, to say for instance, to size a key slot that runs parallel to the Z axis. If I were a shop owner, I would own one. |
| As daewoosan said Go easy on the Eppinger live tooling they are not designed to run 24/7 at max rpm ! And remember to always use the nylon bungs under the non live tools to protect the turret and the live tooling from coolant leakage. |
| i program one at the moment. biggest issue with the machine is no clearances between tool holders cannot cut off diameters same size as the spindle bores cut off tool will rip the way covers up. tools cannot extend very far from the tool block no clearance between way cover and turret
__________________ If you can ENVISION it I can make it |
| cnc-king, I'm confused. According to the tool interference diagram, you can hang a tool 30mm out of the turning tool holders. This should allow you 6mm clearance to the way covers, and should allow you to part off a 60mm diameter bar. Is this not true? |
| DAEWOO LYNX 220LM | jackson | Daewoo/Doosan | 17 | 08-22-2011 11:18 PM |
| lynx 85 | breazr | CNC Plasma and Waterjet Machines | 2 | 02-07-2011 04:02 PM |
| Infracore Product Mix | Gkohl | Daewoo/Doosan | 1 | 01-13-2009 12:43 AM |
| lynx 220 | wilko | Daewoo/Doosan | 1 | 02-02-2007 09:26 AM |
| Daewoo Linx 220LM | scappini | Daewoo/Doosan | 3 | 07-20-2006 03:33 AM |
