Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 04-30-2009, 09:39 AM
markjb is on a distinguished road
turret issue
2004 puma 240L fanuc 21i-TB we had the servo battery go bad 3.6 volt. we replaced that yeserday ran the machine turned on and ran today for an hour then we got alarm 2023 (not locking in the 10 sec interval) then switches to alam 2047 (turret clamp switch alam or turret control unit alarm
Old 04-30-2009, 03:28 PM
Jwl Jwl is offline
Jwl is on a distinguished road
Check your PLC output relay for the clamp/unclamp cct. Chances are both solenoids are in the ON state for the hydraulic turret clamp. This means one of your output relays is fused shut.
Old 05-01-2009, 04:15 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
When you changed the servo battery. did you reset parameter 8 on the promotion unit ?
This sets the 'current' clamped position tool number
If you hit the e-stop can you turn the turret by hand ?
Old 05-25-2009, 02:34 PM
hotrob1 is on a distinguished road
Question Daewoo 2023 error
I got one that has an intermittant turret issue. Works great going CCW but has 2030 error when going CW. I removed and cleaned the Yuken valves. This helped some but still have the error periodically. Swapped battery in servo. Not sure how to reset parameter #8 on promo unit. Any help? Could this be my problem?
Thanks in advance.
Hotrob1
Old 05-25-2009, 06:46 PM
Try M-Man's procedure on this thread
Daewoo Puma 300 lathe turret alarm
this is the procedure to reset the position the turret stops at to clamp
Old 05-29-2009, 09:05 AM
Question Still got it.
I appreciate the response. Still getting 2030 error. (each tool indexing is not finished within 20 sec after tool index command) Thinking it may be the clamp/unclamp confirmation switch. Any thoughts? Thanks.
Re: 2030 error (Daewoo 200)
Old 05-31-2009, 09:05 PM
2030 M17 OR M18 IS COMMANDED IN ILLEGAL MODE, PLEASE CONFIRM MDI MODE.
Please recheck this is the error you are getting
as for checking the turret clamp unclamp
you can either take the guard off and see if the proximity switch at the back is lighting up
or you can change K5.4 and check X7.0 to also see if the clamp confirmation switch is operational.
The fact that it is working in one direction indicates that it is not orientating the turret correctly before it clamps. Which indicates to me that the promotion servo controller is not orientating the turret to the correct position
or overshooting
Old 06-15-2009, 03:49 PM
Update
I turned down the pressure and right now the turret is working w/o errors. It is working slow of course but able to produce parts. I'm going to leave it as is for right now but I do appreciate the responses and may hollar back once it becomes an issue again. Not sure what the pressure had to do with it unless it was running a little high. Again, thanks.
Old 07-01-2009, 03:25 AM
ShortRunCNC is on a distinguished road
i had similar issue, was actualy the limit prox sensor, had to adjust it.
Daewoo Puma 230 Turret issue atscnc Daewoo/Doosan 4 10-15-2011 08:13 AM
Servo Turret Issue Tom Slick Fadal 13 03-03-2008 11:34 AM
Leadwell GTC-20 turret issue hutch07 General CNC (Mill and Lathe) Control Software (NC) 0 12-14-2007 09:23 AM
another turret issue Paul in OK Daewoo/Doosan 0 05-24-2007 12:21 PM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 04:19 PM
