Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 04-23-2009, 11:39 AM
jvanbysteren is on a distinguished road
Question Bar puller for Daewoo puma 8
I am trying to put a bar puller on this machine, I'm pretty sure it is possible. however I seem to be having problems with the chuck clamp interlock I can program a chuck clamp and un-clamp & actuate the bar puller, but when the chuck is in the un-clamp position I can not move the Z position to actually move the part out, is there a trick to this? can I turn off the switch that tells the machine not to move when the chuck is un-clamped? the control is a Fanuc OT.
Thanks John
Old 04-23-2009, 12:51 PM
chucker's Avatar
chucker is on a distinguished road
bar puller
Try using a M31 (main spindle interlock) this should let you move when the chuck is open
Old 04-23-2009, 01:06 PM
paul gibson is on a distinguished road
bar puller
Are you switching from IPR feed to IPM feed when you try to move your Z axis?
If so and you can't get movement in Z axis, I have ran across some Leadwells with Fanuc OT controls that required you to command a spindle speed of 0 before they would allow you to move the axis. We would use this block to prep the movement in the Z axis.
G97 S0;
Then it would execute the movement.
Don't forget to switch back to IPR mode after your bar puller.
Regards
Paul
Old 04-23-2009, 03:41 PM
I have just tried both of these suggestions, and the machine still stops after the chuck is un-clamped (M69).
any other suggestions,
thanks
John
Old 04-24-2009, 10:07 AM
chucker's Avatar
could post the part of the program that is not working
Old 04-24-2009, 12:06 PM
g-codeguy is on a distinguished road
I am thinking there is nothing wrong with your program in which case I can't help you. Here is a sample barpull operation that works on our Puma 8 with OT control.
N100M9 (BARPULL)
G0X6.Z6.M41
T0101M5
X2.Z-1.7
X-1.5
M69
W1.38
M68
G0X2.
Z2.
X0Z6.T0100
M1
Old 04-24-2009, 03:45 PM
thank you, I will give it a try.
Old 04-24-2009, 05:58 PM
Our lathe has the same control as yours. If it doesn't work, then I think it is a pretty safe bet that the program is not the problem. You will need help from someone else as I know very little about the maintenance side of lathes.
Good luck.
Old 06-01-2009, 12:54 AM
mroy0404 is on a distinguished road
Bar puller program
This little program works great on my Daewoo Puma 8s with Fanuc OT-C control.
(BAR PULLER)
T0808
G0X2.Z-.35(APPROACH BAR IN RAPID)
G98G01X0.0F50.0M31(FEED ON THE BAR)
M69(CHUCK OPEN)
G01Z1.055F50.0M31
M68(CHUCK CLOSE)
G01X2.0F50.0M31(FEED OFF THE BAR)
G99(INCHES PER REVOLUTION = G99)
G28U0.W0.(RAPID FROM BAR TO HOME POSITON)
M1
M99
Reply back with your results.
Need Help!- Daewoo Puma 6 with 3tf mmxmb Daewoo/Doosan 1 04-06-2011 08:36 AM
Daewoo puma 8s mroy0404 Daewoo/Doosan 3 06-14-2010 02:58 AM
I Need to buy a Daewoo Puma 8 gcrudgington Daewoo/Doosan 2 10-20-2008 06:24 PM
Daewoo Puma 400 Lathe TURNER Daewoo/Doosan 14 02-04-2007 03:14 PM
Daewoo Puma 200 williamsxu Daewoo/Doosan 10 01-17-2007 05:52 PM
