Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 04-13-2009, 02:31 PM
wilko1 is on a distinguished road
horizontal toolchanger.
hi,
i am having toolchange trouble on a hc 400 horizontal 2 pallet bt40 machine
every so often during m6 the spindle tool doesnt come out but the collet is released, should the drawbar "push" the pullstud to break the taper or is it up to the atc arm to break the seal on the taper?
cheers.
wilko.
Old 04-13-2009, 07:29 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Yes there is usually two reasons this doesn't happen
1. Incorrect pullstud length
2. Incorrect Knockout adjustment *
*Inside the collet there is a bar that impacts the pullstud when you command tool unclamp
Generally this is adjusted at the top of the spindle
Old 04-15-2009, 04:49 PM
wrenchturner is on a distinguished road
Can you manually jog through and continue tool change?
I have seen where nothing is wrong with unclamp however the tool in the waiting pot is not detected as clamped by the proximity sensor and the toolchanger will stop in the with the tool arm looking as if it cannot pull out the tool.
toolchanger on MB3 VMC underdog HURCO 4 03-21-2009 05:42 PM
diy toolchanger??? marcerasmus Wood Working Tooling 2 10-08-2007 12:24 AM
cnc DIY toolchanger??? marcerasmus CNC Tooling 1 10-07-2007 05:30 PM
cincinati toolchanger cyclestart General Metal Working Machines 0 05-23-2005 04:22 PM
