Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
  #13   Ban this user!
Old 03-31-2009, 05:41 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Refer to section 3.3.3 of the Puma 2000 SY Operator Manual
Section Entitled
Synchronous control & torque skip function
K0.0 1=Synchronized Speed 0=Synchronized Speed And Phase
M203 Sub & Main CW
M204 Sub & Main CCW
M205 Sub & Main Stop
M31 Main Chuck Open Closed Allowed While Rotating
M131 Sub Chuck Open Closed Allowed While Rotating
  #14   Ban this user!
Old 04-01-2009, 06:52 PM
seesaw1 is on a distinguished road
Thumbs up This works I'm running now! Sample program below.
N10( MAIN SPINDLE MILL ROUGH SLOT1 );
G0 G19 G40 G54 G80 G97 G98 M8;
M90 G28 V0;
M190;
G28 U0;
G30 W0;
G28 B0;
M35;
G28 H0;
G28 A0;
M110;
T0808 ( ENDMILL0625REG4 X-AXIS ROTARY );
G97 S1004 M33;
G0 B-6.5;
M0;
G97 S1360 M19;
G0 Z-3.5;
M33 S1004;
M89;
M189;
X1.0 Y-0.685;
G1 X0.15 F20.0;
Y-0.364 F3.0;
Z-12.3875 F3.5;
Y-0.685;
G0 X3.5;
Z-3.5;
M90;
M190;
M5;
G97 S3160 M19;
M33 S1004;
M89;
M189;
X1.0 Y-0.685;
G1 X0.15 F20.0;
Y-0364 F3.0;
Z-12.3875 F3.5;
Y-0.685;
G0 X3.5 M90;
M190;
G28 V0;
G28 U0;
G30 W0;
M5;
M1;
MAKE SURE IF YOU ARE GOING MACHINE WITH ANOTHER TOOL NOT TO USE G28H0,A0 OR G30H0,A0. YOU HAVE TO USE S----M19 TO POSITION PART.
AS LONG AS THE TWO PART ARE CHUCKED TOGETHER YOU HAVE TO USE M19 TO ROTATE, IT WILL OVER LOAD SPINDLE AND OR BREAK OR BEND PART!!!
  #15   Ban this user!
Old 04-01-2009, 08:39 PM
This is odd I didn't think the C2 axis went into servo driven mode unless commanded.
Generally you would just use it in spindle mode with no power to the motor
You can use torque function to move the B-Axis on to the shaft and clamp the sub chuck.
M35, Rev. tool stop, Main spindle = C1, Sub = Spindle
M135, Rev. tool stop, Sub spindle = C2, Main = Spindle
  #16   Ban this user!
Old 04-01-2009, 09:52 PM
Daewoosan is on a distinguished road
keep relay may need changed
I suggest you look in the blue book in your electrical cabinet and find keep relay 10 bit 3. if you make bit 3 a 1, this should allow the "inactive" spindle to "freewheel" while the "active" spindle does all the driving.
After confirming that K10.3 is the correct keep relay, turn on your parameter write enable from the offset/settings page. You have to be in MDI to make these changes, so keep this in mind. Make the PWE a 1 and press input. You will get an alarm in regards to the Parameter write being enabled. This can be cleared by holding the Cancel button (CAN) and then pressing Reset.
Press the "System" hard key, then press soft keys, PMC, PMCPRM, KEEPRL, these are the keep relays. Use your arrow on your keypad to cursor to the fourth digit from the right and make it a 1 (1 then Input). Turn your PWE back to a 0, and you should be ready to roll.
  #17   Ban this user!
Old 04-04-2009, 08:05 AM
BAD DOG is on a distinguished road
THE MAIN IS A FULL -C,,, WHILE THE SUB IS ONLY AN INDEXING,,,YOU MUST DIS-ABLE THE SUB AND USE THE MAIN AS A DRIVER,,,, IN EFFECT THE SUB WILL FREE WHEEL AND BE DRIVEN BY THE MAIN
BAD DOG
  #18   Ban this user!
Old 04-04-2009, 03:46 PM
dcoupar's Avatar
Bad Dog,
Do you have a 2000SY with "indexing" sub-spindle? Every one I've ever seen has a full C on both main and sub.
Here's a snippet from the proposal.
Name:	Puma 2000SY C-axis Main and Sub.jpg‎
  #19   Ban this user!
Old 04-05-2009, 01:27 PM
My bad I had 240 MSB on the Brain!!!!!
Problem- Lathe in Edgecam: Spindle-docking from Sub to Main HarmH EdgeCam 2 03-04-2009 04:20 AM
Changing the main drive belt on the spindle Michael82 General Metal Working Machines 1 01-06-2009 08:09 AM
puma 400LM main spindle stabillity, got any? M-man Daewoo/Doosan 1 03-22-2008 07:21 AM
FANUC AC MAIN SPINDLE problem!! Cole84 Fanuc 11 11-21-2007 10:12 AM
How to control the speed of the main spindle? george128306 Hobbycnc (Products) 5 04-15-2006 04:00 AM
