Results 1 to 5 of 5
Thread: promotion turret drive help, on a puma 240msb
    Nov 2008
    I have a Daewoo promotion ac servo drive on our Puma 240msb. The turret will not index and shows it is at tool 00 when it is actually setting on tool 5. if you push alarm reset or tool index button, it flashes between tool 00 and tool 12. The servo drive has an error ALP-En on the display. Does anyone know where I can download a service manual for this drive? Or have experience with this problem.
    Oct 2008
    alp-en is a low battery alarm.you need to get a 3.6 volt litium battery aa size radio shack usually stocks them.after changing the battery you will need to reset the drive.the procedure should be in your parameter manual.if not i can walk you through it
    Nov 2008
    Yea thanks, I got it figured out. I finally found the right book.
    May 2005
    VietNam
    Pro-Motion document need
    Quote Originally Posted by raygun View Post
    Hi Raygun,
    My machine turret lost parameter, could you please help me set paramater.
    Jung
    Jun 2009
    CHN
    contact me ,maybe I can help u!
    1. Daewoo Puma 230 Turret issue
      By atscnc in forum Daewoo/Doosan
      Last Post: 10-15-2011, 08:13 AM
    2. Puma 600/700 coolant leak from turret
      By jani in forum Daewoo/Doosan
      Last Post: 02-20-2010, 08:03 AM
    3. turret trouble on a puma 200c
      By krow in forum Daewoo/Doosan
      Last Post: 04-15-2009, 04:29 PM
    4. Puma 8s turret grinding
      By mroy0404 in forum Daewoo/Doosan
      Last Post: 06-12-2008, 07:03 AM
    5. Need Help!- puma 6-3a turret positioning
      By wbmach in forum Daewoo/Doosan
      Last Post: 04-13-2008, 12:06 PM
