| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
i have a 1996 daewoo puma 200c with an 18t fanuc control. the machine has a tool setter but i have no info in the book on the correct way to use it. i want to be able to use it manually to touch tools off and i want to know if it can be used as part of a program to make sure the tools are still cutting at the right size. the tool arm will open and close with m-codes but that is as far as my daewoo book shows. is there anyone with the info to tell me how to use it correctly.i have checked with my local service center but have gotten nowhere, there answer for any question i have had is that the machine will not do that without even checking the model or serial numbers. p.s.- i bought this machine used, maybe that is why they dont want to answer. any help i could get i would greatly appreciate it. Last edited by spirowski; 01-30-2009 at 09:21 AM. Reason: differant title |
| I've never used one to check offsets during a program, but I've used them to manually set tools. 1. Index the turret to the tool you want to set. 2. Lower the Q-setter, and the display should show the GEOM offset page with the correct tool number highlighted. 3. In HANDLE mode, move close (within .04 or so) to the contact point for Z. 4. JOG until the tool touches the contact (the machine should stop when it touches). This should store the offset in Z. 5. Jog off the contact, and repeat 1-4 for the X. Repeat steps 1-5 for the remaining tools. In MDI, activate the tool offset, i.e. T0101 for a tool that you can use to face the end of the part. Take a clean-up cut then ,before you move Z, set your G54 Z offset in the WORK offsets by moving the cursor to G54 typing "Z0" and press MEASUR. Your Z absolute should now read 0. If the diamters are incorrect, you will probably want to adjust the probe parameters to correct them. |
very nice exp. thanks.
| looking for Mike Laws.... | pete from TN | Benchtop Machines | 0 | 03-30-2008 06:36 PM |
| Hey Mike.. | l u k e | Torchmate | 14 | 12-03-2007 12:15 PM |
| ? for Mike | jb_swampfox | Torchmate | 4 | 07-02-2007 12:35 PM |
| What about Mike? | warpedmephisto | Industrial Hobbies (Support forum) | 7 | 05-04-2006 08:09 PM |
| I want to be like MIKE | Binderman | CNC Plasma and Waterjet Machines | 1 | 01-18-2005 11:01 PM |
