| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
Hello all, i just fixed my Ecoca SJ-35 Lathe that had dead for 2 yrs. the batteries died and lost all parameters. I just got it fixed last night, and am in need of a simple little program to test everything out. I have only programmed Haas before, so this Fanuc controller is all wierd for me. I tried to write a little program in it, but kept getting a 10 or 11 alarm when it came to a "move" what am i doing wrong? ~all i need is a start to finish program, that will move the Z and X seperate and then together. I can modify the coordinates later. another issue for me is it in MM? how do i swap it to INCHES? it wont let me change it on the Parm/Diog. page. i have tried everything! |
| Hallo My name is N.Sachin In Fanuc control P/s 10 Alarm is , Improper G code., I.e you are using the G code which are not enabled in option group. P/s 11 is Feed rate missing , you have not given F command in the program. After referencing the machine you just follow the below sequence O0001: G0 G53 X0 ; G0 G53 Z0: G4 X5.: G0 X-100.: Z-150: G4x5.: G0 X0 Z0 ; M30: you test this program for axis movenent in rapid feed, you can alter accordingly. For MM to INCH conversion you need to change NC parameter also inaddition to changing this in setting page. Hope you can test the machine now Good luck |
| i tried changing in the settings page, it wont let me? i turned on my "PWE" to a 1, then tried to change the "inch" to a 1. but it will not change. what parameter needs to be changed. only one I see that relates to the inch/mm is 63 |
| What series Fanuc control are you using? I change mine with the G20 and G21 code. G20=english, G21=metric. A few odd times I had to use G70=english, G71=metric. Program this in MDI. Make sure your machine is reference returned as my machines want to move to home position before converting the numbers. It does only move if you are actually switching. Ex. if you are in english and you program a G20 machine does not move. Stevo |
| parameter ? | KENNETH BROWN | Fanuc | 2 | 03-11-2008 07:23 PM |
| parameter | davek | Fanuc | 6 | 11-08-2007 07:45 AM |
| dnc parameter help | shepherd | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 06-27-2007 12:28 AM |
| Parameter changes | jorgehrr | G-Code Programing | 9 | 02-15-2007 08:06 PM |
