| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
Hi. My first time here. I just started working on a Daewoo V35 w/ a fanuc 0-M control. It's a new control to us and we can't figure out 2 things. 1) How do you use cutter comp. There is no place in the offset page for any comp values. 2) Can't do a tool change in MDI, I have to actually use a little prog and keep changing to T # to change tools. Also there is a manual lever 2 positions away from the spindle position to open to carousel grippers, but I can't figure out how to clear the tools with the Z axis or manually rotate the carousel. Any help would be greatly appreciated. |
| My guess is you have "Tool Offset Memory A", which gives you 99 (or more) offsets which can be used for length compensation or diameter compensation. For example, for tool #1 you might use offset #1 for length compensation, and offset #21 for diameter compensation. G43 Z0.1 H01 (ACTIVATE OFFSET NUMBER 1 FOR LENGTH) G01 Z-0.54 F20. G41 X0 D21 (ACTIVATE CRC LEFT WITH OFFSET #21) |
N008 M03 N009 G00 Z0.25 N010 G00 G54 X0.048 Y0.45 [MODIFIED FOR LEAD IN] N011 G43 Z2.0 H1 G1 X.01 F15. N012 G42 [START CUTTER COMPENSATION] N013 G01 X0.114111 Y0.400531 N014 G01 X0.45302 Y0.261491 N015 G01 X1.860796 Y0.226731 N016 G01 X7.655644 Y0.3977 N017 G01 X4.448235 Y0.878479 N018 G01 X2.032423 Y0.939309 N019 G01 X0.57468 Y0.6873 N020 G01 X0.114111 Y0.400531 G40 ( cutter compensation cancel) II.... MDI tool change you have got Daewoo machine, so it should be Fanuc control put M6T1 for MDI tool changes. carousel is this rotary table ? |
| CNC programming - HELP | kyo_ysh | General Metalwork Discussion | 3 | 01-11-2010 09:42 PM |
| Need Help!- programming | rajanvadakkepat | Fanuc | 6 | 10-10-2009 09:22 AM |
| CAM programming | mallinathan | Diemaking and Diecutting | 0 | 10-19-2008 12:08 AM |
| Cnc Programming Course | millmonkey1 | G-Code Programing | 0 | 02-20-2008 02:54 PM |
| CNC Programming | qman | General CAM Discussion | 7 | 10-16-2007 01:34 PM |
