| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
I have always always from setting up days to training had it so my X zero is the center of my ID pot. IE you never put an X offset in a drill. Now this new company i have started for, have a few habits one of them being i believe its wrong Q setting the side of drills as the X zero is out. This is a straight 2 axis lathe. Puma 250 To get the zero back i can input the value in the External offset, or i used to use parameters to correct this but i cannot remember the parameters. Also once this is done i will need to reset the Qsetter for them, any ideas on the parameters for this as i cant find the manual. Its a meldas 500l series. Thanks |
| I know this is an old post but .... ACCESSING THE MACHINE PARAMETERS 1. GO TO THE ALARM/ DIAGN SCREEN 2. PRESS THE PLC-I/F MENU 3. KEY IN 1001 FOR THE DEVICE, CURSOR RIGHT 2 TIMES AND KEY IN M UNDER MODE 4. PRESS THE INPUT KEY, AND THE (1001) ( ) ( M), WILL DISAPPEAR 5. GO TO THE TOOL/ PARAM SCREEN These parameters are from a M625 manual the numbers may be different but the parameter name should be the same AXIS PARAMETERS (Grid Shift) 2027 G28sft (Tool Sensor) 2015 t1m1- 2016 t1m1+ gl |
| Changing Datum | mrcodewiz | Dolphin CADCAM | 2 | 10-10-2008 05:40 PM |
| Problem- Move subspindle datum | Kai_DK | EdgeCam | 3 | 05-22-2008 11:43 PM |
| Datum Help Needed | TZ250 | Dolphin CADCAM | 3 | 05-28-2007 11:22 AM |
| Datum Shift with TNC530 | Bubbles | General CNC (Mill and Lathe) Control Software (NC) | 1 | 07-20-2006 05:23 PM |
| Grid Shift | scuba | General Metal Working Machines | 1 | 10-13-2004 03:50 PM |
