| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
Hi I wondered if anyone could help me. I have recently aquired a daewoo puma 240L cnc lathe with fanuc OI-TB control. What i want to know is how to writ e text and give the programs a title. Any help would be appreciated. |
| If you're entering programs at the control, in EDIT mode, you key in the letter O, and up to 4 digits (0-9), and press the INSERT key. O1001 - INSERT will create program #O1001 in the memory. You can they type in the blocks followed by an EOB ( and INSERT them.If you're typing them offline (in Notepad, or some other text editor), your file should look like this: % O1001(PARTNO 1234 REV1 OP1) <-----comment is optional ... ... ... M30 % |
| Parameter 3204 bit 0 will change the "[" and "]" keys to "(" and ")". If you edit macros, you'll need the "[" and "]", however. Parameter 3204 bit 2 will turn on the C-EXT soft keys, which will give you "(", ")", and "@" soft keys. |
| WARNING: BE CAREFUL WHEN CHANGING PARAMETERS!!!! In MDI, press OFFSET/SETTING then press the [SETING] soft key. Move the cursor to PARAMETER WRITE =, type 1 and INPUT. You'll get a P/S100 alarm... ignore it. Press the SYSTEM key, then the [PARAM] soft key. Type 3204 then press the [NO. SRH] soft key. You'll see a row of 8 0's or 1's (bits). Bit 7 is the left-most bit, and bit 0 is the right-most bit: ( 7 6 5 4 3 2 1 0 ) If you're never going to need to edit Macro's, change bit 0, otherwise, change bit 2. Cursor > until the bit you want to change is highlighted. Type in the new value (0 or 1) and press INPUT. Press OFFSET/SETTING and change PARAMETER WRITE = back to 0, then RESET the alarm. If you changed bit 0, the "[" and "]" keys will now give you "(" and ")". If you changed bit 2, you should be able to press the > soft key while editing and see the [C-EXT] soft key. When you press this key, you'll get soft-keys for "(", ")" and "@". |
| Daewoo puma 8s | mroy0404 | Daewoo/Doosan | 3 | 06-14-2010 01:58 AM |
| Daewoo Ace V400 | rags | Daewoo/Doosan | 4 | 02-17-2009 05:29 AM |
| New To Daewoo..... Any Others | rolinjunk | Daewoo/Doosan | 7 | 02-16-2009 04:05 PM |
| Daewoo 12L | toolendmill | Daewoo/Doosan | 1 | 03-07-2007 06:09 PM |
| Daewoo ACE-H80 | Cncjunkie | Daewoo/Doosan | 7 | 03-13-2006 06:55 AM |
