Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 11-21-2008, 06:44 PM
joesimmers is on a distinguished road
Lynx 220a or 220c reccomendations
Hello, I have a one man shop and am interested in adding cnc lathe work to my shop.
I have been looking at used cnc lathes, talked to a dealer today and was surprised the deal I could get on a brand new Lynx.
I am unsure whether to get the 220a or 220c.
The 220c gives you an 8 inch chuck instead of 6 inch chuck and a 2.625 bar capacity diameter versus 1.75 for the 220a.
The 220a is 6000rpm where the 220c is only 4500rpm.
I am a small job shop and undecided which to get since I currently do not do any cnc lathe work.
I can get a much better deal on the 220a, and also a tailstock.
Any reccomendations greatly appreciated.
Thanks, Joe
Old 11-23-2008, 07:41 PM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
I was in the exact same situation as you and we went with a used Lynx 200, with the tail stock and 6" chuck. For the work we were doing the diameter was not the problem but the fact that the Z travel is short. The most we could bore was about 5.5" deep because the travel was only about 12".
If it is a lot cheaper and you think it will work for your sizes go for the little one, but then again even 4500RPM is plenty enough speed.
Daewoo are good machines though, unfortunately I got stuck with a Mitsubishi controller.
Live free or die
Haas Lathe Reccomendations imwllc Haas Mills 17 04-05-2012 12:21 PM
Upstroke press brakes - Reccomendations? PhoenixMetal Bending, Forging,Extrusion... 5 07-27-2008 03:48 PM
lynx 220 wilko Daewoo/Doosan 1 02-02-2007 08:26 AM
Lynx 220A question PBMW Daewoo/Doosan 5 12-26-2006 06:24 PM
Reccomendations milford DIY-CNC Router Table Machines 1 10-14-2004 02:57 PM
