Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 11-20-2008, 03:34 PM
harleydog's Avatar
harleydog is on a distinguished road
Unhappy DAEWOO PUMA 10 Z AXIS PROB
Need help!!!
I have a Daewoo Puma 10... When I thread a shaft it has some slop in z axis and makes a poor thread (.014 slop) in Z.. On indicator.. I Need help in repairing.... I think something is loose.... sheer rings are ok (left side)... I have machine covers off TO VIEW.. I wonder if it is a problem at thrust bearings at end (left side).. Or some sort adjustment
Any help will be great... machine down and I am lost.
Thanks Mark
Old 11-28-2008, 06:47 PM
harleydog's Avatar
bearings bad on z axis ....replaced and works fine
Old 11-30-2008, 02:31 AM
shay z is on a distinguished road
few options:
1: worn X axis lining (if you cut varible load chip tou will see th whole turret moving up and down). replacement of the torqite (if the spelling is right) lining is not a big deal and takes about 2 h work and one day for the glue to cure.
2. look behind the spindle. maybe the bolts that hold the head to the bed are loose.
3. bearings problem.
Tags
daewoo puma 10 "z" slop
Need Help!- Daewoo Puma 6 with 3tf mmxmb Daewoo/Doosan 1 04-06-2011 07:36 AM
Daewoo puma 8s mroy0404 Daewoo/Doosan 3 06-14-2010 01:58 AM
I Need to buy a Daewoo Puma 8 gcrudgington Daewoo/Doosan 2 10-20-2008 05:24 PM
Daewoo Puma 8 PWE issue jvanbysteren Daewoo/Doosan 5 07-31-2008 06:45 PM
Daewoo Puma 200 williamsxu Daewoo/Doosan 10 01-17-2007 04:52 PM
