Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 10-01-2008, 06:23 AM
alesko05 is on a distinguished road
Cool Doosan Z290SMY turret problem
I have crashed with the upper torret in B axes. The turret has rotated for around 10 degrees. Is it possible to rotate the turret with wheel and how?
Old 10-05-2008, 08:04 AM
resuengineering's Avatar
resuengineering is on a distinguished road
look at your electric door, if there is a blue book with the machine
in the book stands KEEP RELAIS, there is prob. one for manual turret turing.
some versions you can rotate the turret when its powered up, rotate the turret and hit the emerency button, turret will stand out and can be hand turned.
turn the turret bij hand to a position, set the promotion driver to the same position as your turret is. and that should be fixed.
you also need to line up the turret again, and check the b-axis, cut a piece of metal and check it's not tapered
HAAS SL-20 TURRET PROBLEM HELP allmotormatt Haas Lathes 11 01-19-2011 11:47 PM
Turret Indexing Problem SL4 ndp Machine Problems, Solutions , Wireless DNC, serial port 11 06-30-2009 10:39 AM
doosan fanuc 18t turret julio_gyn Fanuc 3 05-19-2008 12:43 PM
SL 10 turret problem PBMW Haas Mills 1 08-15-2006 08:51 PM
Mazatrol T32 Turret Clamping problem sunrock_83 Mazak, Mitsubishi, Mazatrol 5 02-08-2006 10:38 AM
