Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 09-17-2008, 10:39 AM
Donnie57 is on a distinguished road
Doosan S 280 Fanuc 9000 parameter for M06, M07
I need the 9000 series parameter(s) to enable a parts catcher. I hooked up the sol. valves, reed switches, etc. and the diagnostics see the inputs going high as I manually cycle the air cylinder. The solid state relay and solenoid for parts catcher return is live but the machine won't respond to M06 or M07. Thanks, Donnie
Old 09-17-2008, 11:56 AM
chucker's Avatar
chucker is on a distinguished road
PARTS CATCHER
I may be wrong but I think you need M10 and M11 for your parts catcher
Old 09-17-2008, 12:12 PM
cnc-king's Avatar
cnc-king is on a distinguished road
you need to let the machine know the parts catcher is attached to it
keep relay K8.5 activates and deactivates the parts catcher check your manual or if you can understand the ladder logic go thru it and look for the parts catcher. the keep relay and parameter ( if needed) is listed there
i do not think it is a parameter you have to change but it is more than likely it is the keep relay
If you can ENVISION it I can make it
Old 09-17-2008, 01:08 PM
Keep Relay and M Code
I checked the book and the only reference to a keep relay (K4 bit 6) is "Parts catcher on axis interlock". The Doosan manual lists M6 and 7 for the parts catcher. Thanks so much for the quick replies guys...... Donnie
Old 10-05-2008, 08:15 AM
resuengineering's Avatar
resuengineering is on a distinguished road
@chucker
you're right, part catcher M-codes are M10 and M11 unless user modified.
standard doosan its M10 and M11
Old 03-27-2009, 12:54 AM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
Originally Posted by resuengineering View Post
@chucker
No. The M-codes for the Mecatec/Doosan S280 Parts Catcher are M6 & M7
Doosan S280 M-Codes.pdf As shown by this extract from the S280 Operators Manual
I do not know how to turn on the Parts Catcher
Which Fanuc control do you have on this machine ?
FANUC 15M Parameters 9000 how to enter? posedi Fanuc 13 04-28-2010 07:33 PM
doosan fanuc 18t turret julio_gyn Fanuc 3 05-19-2008 12:43 PM
Back up 9000 range on Fanuc 0M-C OC_ Fanuc 5 01-16-2008 02:32 PM
Need 9000 parameters from Fanuc 18T help please Lex_1972 Fanuc 2 02-14-2007 08:10 PM
9000 series parameter list IcutPoly Fanuc 1 11-12-2006 05:08 AM
