| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
| HELLO EVERYBODY, I'm trying to program a tailstock but I get the following alarm: M78 or M79 or M70 is not finished within 15 sec after command, check solenoid valve, switch position or program condition. Actually I do not know what I have to do, I appreciate your help Thank you |
| When you send the tailstock out with an M function (as in a program), it needs verification that it has extended to where it is supposed to be. Typically there is a panel on the side of the tailstock facing the operator. Behind this panel are two swtiches for tail stoack back and forward. You need to adjust the forward switch or actuator so the control sees it and verifies your M function. George
| If the proximity switches get to be a pain, I usually shut off the keep relay that controls them. It should be keep relay 8 bit 7. Please check in the blue book on the electrical cabinet door (unless someone has moved it of course), to make certain this is the correct keep relay. |
| What is a Programable Logic Controller? | tobybirch007 | PIC Programing / Design | 5 | 01-19-2008 08:55 AM |
| WINCNC Programable down force | synd00d | WinCnc | 6 | 03-03-2007 08:32 PM |
| Conversion to programable independant heads for Gantry Twin head router table | ohallock | DIY-CNC Router Table Machines | 0 | 04-18-2006 06:20 PM |
| Retrofit of Mill with programable DRO and power feeds | Paraprop | General Metal Working Machines | 3 | 01-31-2005 12:57 PM |
