| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
Hello ., I own a daewoo puma 230 msb with controller fanuc 18i, is there any G code for drilling in X axis with the live tooling or I have to program it in G01 ? I am looking for a G code like G81 or G83 but for the X axis , I have been trying G87 but I have an alarm G-code error Okk thank |
| what is your control? Daewoo has it own control I don't think it has Fanuc..... I had never worked with Daewoo before, but one time I read their program manual and from what I remember, can cycle for Daewoo is difference then Fanuc, so check your manual.
__________________ The best way to learn is trial error. |
| hi thanks for the help , Yes my controller is a FANUC 18i-t year around 2001 I have try G87 and dont work , my featurecam program the block like that M33S2000G0G54G98: G0X2.0Z-1.0: G87U-0.200R0F5.0 G28U0W0 I have try change the U-0.200 by X-.200 and X .200 but always the same result , it says Improper G-code 010 , even when I just type G87 in mdi mode I end up with this I think its maybe a parameter that is wrong or this fanuc dont have the option of drilling in the X axis , ok if someone have an idea let me know thanks ! |
| This is a sample that came in the Daewoo MS200 we bought. :3456 (RADIAL DRILL) G0G40G80 G50S1500 M35 G0T0606 G97S500M33 G54Z.1C0. Z-.5 X6.0 G98G87X3.5Q2500F20.H45.K8M89 G0G80X6.0 Z.1M35 G28U0. G28W0. M30 Another drilling example in the control upon purchase. :2345 (SAMPLE AXIAL DRILL) G0G40G80 G50S1500 M35 G0T0404 G97S500M33 G54Z.1C0. X3.0 G98G83Z-1.0Q2500F20.H90.K4M89 G0G80Z.1 G99 G28U0.M35 G28W0.H0. M30 How I program an axial drill. N1000G54M91 (LIVE SPOT DRILL) M35 T1010M8 S300M33 G98X1.874Z.5C0 Z-.425S5000 G83Z-.55Q3000F20.H90.K4M88 G0Z.5M35 M90 M91 M1 Not sure if I have a sample of the G87 used in one of my programs. I normaly use G1 as I seldom use a spot drill unless also tapping. Thus I feed very slowly until the drill point is into the material before kicking up the feedrate. Can't do that with a G87 cycle unless you want to run it twice. M88= low pressure clamp, M89= high pressure clamp, M90 cancel clamp pressure on our lathes. Don't know if the M35s are necessary. I do know that we have to start the live tooling at S300, make a move & then kick RPM to desired level as the tool doesn't always catch and alarms out if started much faster. EDIT: Not sure if the samples that were in the control upon purchase are 100% correct. I don't see an M90 to cancel the high pressure clamp. |
| lathe live tool in MC | cnc-king | Mastercam | 3 | 04-28-2008 01:56 PM |
| live tool h#2 in maier | maximusek | CNC Swiss Screw Machines | 0 | 01-08-2008 03:30 PM |
| O.D. milling with live tool | jackson | Daewoo/Doosan | 5 | 07-02-2007 08:43 AM |
| Live Tool Holder | JerryH | Fanuc | 1 | 02-12-2006 05:56 AM |
| Miyano Live-Tool | JerryH | G-Code Programing | 2 | 10-26-2005 07:50 AM |
