Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 05-29-2008, 03:17 PM
BAD DOG is on a distinguished road
VMC FOAMING
NEWER DOOSAN 30 X 16 WITH THRU SPINDLE COOLANT (HANGSTEFERS)
HAVING FOAMING PROBLEMS AND PUMP IS SUCKING FOAM,,, COOLANT IS FULL BUT THE THRU SPINDLE PUMP SOMETIMES MOANS WHILE SUCKING FOAM.
I AM USING ANTI FOAM BUT DOES NOT WORK,, ANY GOOD COOLANTS OUT THERE?
BAD DOG
Old 05-29-2008, 09:41 PM
DocHod is on a distinguished road
I have been using Hocut 795 it is a bit pricey but I do not have foaming problems any more.
Old 05-30-2008, 10:30 AM
fixitpablo is on a distinguished road
The Hangsteffers with anti foam additive never has given me problems.
My guess is you are sucking air somewhere.
Old 05-31-2008, 08:32 AM
PBMW is on a distinguished road
If youare using S500cf with the anti foam additives, (I was) and having foam issues, you might try Hangsterfers Neocut 300. I have a couple of 1000psi pumps and have no foam issues....
Coolant foaming problem Larry Myers Sharp CNC 23 07-20-2010 10:59 AM
