Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 04-21-2008, 02:52 AM
nik_chris is on a distinguished road
Cintrol freeze whille simulation
Hello everybody,
I have a PUMA240MS with fanuc 18i control.
many times when I am programing a complex shape for 3axis miling and after that I am trying to execute simulation, the control freezes and finally I have to power off the machine to work again.
Two time this problem appeared in Auto mode while the machine running a program. The axes stoped moving and the spindle continue rotating at the same position.
I have upload the latest version of manual guide which Doosan send me but nothing really happened.
Does anybody have any idea what could be the problem?
Chris
Old 04-21-2008, 09:23 PM
Daewoosan is on a distinguished road
Make certain that you have all of the tool radii/diameters in the tool offset page (including drills) correct. Manual Guide will not simulate correctly without this information and will give you the assumption that the control is locked up.
I would view the graphics from the NC side and see if this solves the problem, as the NC side is not as persnickity as the Manual Guide side when it comes to simulation.
NC Simulation 5axes Visual Basic 9 07-06-2009 02:57 AM
Programs freeze on M08 command Noizemaker31 Fanuc 3 02-06-2008 10:30 AM
Need info about freeze clamping maartenlecleir Work Fixtures and Hold-Down Solutions 18 09-11-2007 06:41 AM
Computer Freeze rweatherly Machines running Mach Software 0 12-06-2006 01:56 PM
Simulation only ? patrickb FeatureCAM CAD/CAM 4 05-27-2006 08:01 AM
