Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 01-21-2008, 11:22 PM
bluej_x is on a distinguished road
monochrome crt hard to read
My company bought a used Daewoo Puma ### with a Mitsubishi Meldas Controller with an amber monochrome display. Not sure the vintage, but maybe early 90's.
The monitor is getting really hard to see.
Is there a way to adjust the brightness on this thing?
Old 01-21-2008, 11:36 PM
Sometimes on these CRTs there is a knob on the side that adjusts the brightness. Also sometimes the housing has a little hole that you can put a screwdriver through to turn the knob; it has a slot for a screwdriver. You will need to take the covers off and see what you can find.
Old 01-22-2008, 12:00 AM
Al_The_Man's Avatar
For that vintage the crt emission has probably dropped quite a bit, is there burn-in on the screen? IOW Do you see characters on the screen when turned off?
You may squeeze a bit more out with the brightness as geof said.
In the mean time you could look around for an old Monochrome monitor, with the same crt size, and just swap the CRT.
Old 01-23-2008, 12:55 AM
Thanks Geof and Al the man. I try to take a close look for a little hole inside and out but couldn't find any kind of adjustment knob on the outside of the controller, or inside for that matter.
If I can remember tomorrow (alzheimer's and demetia) I'll take a picture of it to post here. Is there a limit to the size of pictures we can post? My pone has a 2meg pixel camera and I have it set to max resolution (1632 x 1224) but can lower to (640 x 480) and (160 x 120). Will also look closer for year made.
Old 01-23-2008, 12:57 AM
Al, the burn in isn't that noticeable.
Old 01-23-2008, 08:20 AM
Originally Posted by bluej_x View Post
.... Is there a limit to the size of pictures we can post? My pone has a 2meg pixel camera and I have it set to max resolution (1632 x 1224) but can lower to (640 x 480) and (160 x 120). ...
Yes, when you click the Manage Attachments button for the window to upload pictures it gives you a list of file types and sizes;1025 by 1000 is maximum for jpg.
Old 01-23-2008, 05:01 PM
Al_The_Man's Avatar
Download Irfanview, excellent viewer and pic resizer for posting here.
Old 01-30-2008, 10:54 PM
Just an update:
The monitor took a dump and now we're buying a replacement. $800+
Must Read for All CBNDude Product Announcements & Manufacturer News 16 07-21-2005 09:14 PM
