| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
I have a Daewoo Lynx 200B, I have noticed that the spindle, when spinning is getting louder. However, when spinning by hand, it is still extremly easy. My first thought is the bearings (I hope I'm wrong) does anyone have any experience with this same problem? Could it be something other than the bearings? The lathe is six years old, very light duty machining. FXRGUY |
| The spindle bearings will be noisy if they are worn or damaged. To check them it is best to remove the belts to take tension off the drive pulley. you can then check for lift and end float in the spindle using a 0.0001" indicator and a bar. put the bar down the spindle and try to lift it using a bit of force. look at the deflection of the indicator, it should have no more than 0.0003" lift and it should spring back to zero. Use a plastic hammer to gently tap the spindle forward and back, there should be no more than 0.0002". The spindle should feel smooth to rotate with no lumpiness. refit only good belts and never overtighten them. |
| keep the noise down! | SIMONSIGNS | General Electronics Discussion | 14 | 12-04-2008 11:42 AM |
| How do you deal with the noise from the spindle pulley? | david_geng | Syil Products | 0 | 07-08-2007 06:03 AM |
| Way Oil and Spindle Noise | ETM Shop | Syil Products | 14 | 01-28-2007 09:06 PM |
| Porter cable spindle noise reduction or alternative? | paulr4 | DIY-CNC Router Table Machines | 6 | 03-26-2005 12:56 PM |
| spindle electrical noise | balsaman | General Electronics Discussion | 9 | 10-21-2003 08:41 PM |
