| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
I wonder if this is possible, machine running is daewoo puma 2500st, the problem with tool load values that there is no way to "save" them, have to write them manually each time part changes. Ie, if i put some subprogram call on start of each program which writes new values to tool loads. 10-20 tools, 9 possible axis on each tool + min max values. (Ofcourse not using that many) .. while at it, i could ask your opinion about the whole tool load system. It seems to be bit "flawed", kinda hard to get good working values which would stop the machine when needed etc. ... Dunno if i wrote this to right forum, correct me if im in the wrong place =) |
| Mystiks You have a MX2500 st ? And if i read you right , your looking to save the tool offsets with/when down loading the program? (or just output to card). Do you use the toolsetter with the b axis at zero when setting tools . I know the mx machines iv used the tools didnt leave the machines so uploading the offset wasnt done. New part ment new jaws, rest g54/g55 and the passoff point for the sub spindle, and run the parts.Any time the top axis had to be moved I used the M400 and all the offsets were recalculated. Way sweet.If your not useing the M400 have your dealer show you how it works Do you have a lower lathe turret on your machine? |
| Algorithm for G02 / G03 coding | jemmyell | Coding | 19 | 08-06-2009 05:58 PM |
| New to G-Coding | Larry Myers | G-Code Programing | 4 | 09-20-2007 09:06 AM |
| Tool Load Alarms | BAD DOG | Daewoo/Doosan | 0 | 03-18-2007 05:25 PM |
| Tool holder dimension parameters? | MichaelHenry | SprutCAM | 5 | 12-23-2006 02:43 AM |
| G2/G3 Coding | jrobson | G-Code Programing | 24 | 09-02-2006 12:54 PM |
