Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 10-17-2007, 10:37 PM
bdyenter is on a distinguished road
Smile A suggestion for tailstock quill not advancing
First try M78 and M79 in your MDI mode. If you cannot get the quill to advance then check the electrical schematic for your tailstock advance and retract. Find out what number parameter it is and check the correct bit or binary digit. Something tells me it's like the 6th bit and it should change from 0 to 1 or vise versa at this bit and parameter address. If it doesn't then you have a micro switch gone bad. You will have to take off the cover on the tailstock and shut the power off first. Then replace the micro switch. Sometimes the tailstocks have 1-2 micro switches on the dogs for the travel of the tailstock quill and then 1 usually on the pin that you pick up your tailstock with the turret. I would check this one first. These switches are about $10-12 at Grainger. Just make sure you mark where the 24v wire goes and the ground or you'll fry the 24v fuse or the board.
Router suggestion Toysrme DIY-CNC Router Table Machines 3 03-10-2007 07:42 AM
A suggestion shreifali General Metalwork Discussion 0 02-05-2007 08:44 PM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 05:20 PM
A suggestion and a thank you.. murphy625 Suggestions for the CNCzone.com site. 1 03-05-2005 07:02 PM
New guy and I need suggestion. dmgdesigns DIY-CNC Router Table Machines 7 01-31-2004 05:29 PM
