Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 10-17-2007, 10:24 PM
bdyenter is on a distinguished road
Little extra help for tailstock
You can inject the pin and indujet the pin with M46 and M47 I believe.
If the tailstock is programmable that way. Then you can incorporate these M codes in your program and pick up the tailstock from Z home position and drop in front of part. Then at end of program you and come pick up and drop off at home position as well.
Just need Extra Income SPYLAGZ Employment Opportunity 0 08-09-2007 02:44 AM
Extra capacity cdlenterprises Employment Opportunity 1 02-26-2007 01:58 PM
tailstock (mis)alignment ajbarrell Shopmaster/Shoptask 8 01-06-2007 10:18 PM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 05:20 PM
Need help extra lines in dxf carlnpa Mach Software (ArtSoft software) 3 03-19-2005 03:48 PM
