Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 08-28-2007, 10:29 AM
davey242 is on a distinguished road
Pallet Identification on Daewoo w/Mits control
I have a Daewoo with the Mits control (Meldas 500M). Does anyone know how to identify which pallet is in the machine? You can use M45/M46 for a pallet check to make sure the right pallet is in the machine but I want to load offsets based on which pallet is in the machine.
With a fanuc control you can use the custom macro's to read which pallet is in. Is there a way to read a parameter on the Mits control or to change a common variable base on the pallet in the machine?
any insight would be much appreciated.
Thanx,
Daniel
How to do Tool Changing on Mits MV-70E w/ Meldas 520 icnc Mazak, Mitsubishi, Mazatrol 0 06-26-2007 11:30 AM
Mits FX2 Wire EDM Problem. weblogictech CNC Plasma and Waterjet Machines 1 12-16-2006 12:28 AM
mits sinker edm mmachining CNC Plasma and Waterjet Machines 1 06-19-2006 02:31 PM
ex8 mits sinker question! KANNON123 CNC Plasma and Waterjet Machines 3 01-28-2005 08:02 AM
Mits Vs. Charmilles GOOCH CNC Plasma and Waterjet Machines 2 08-27-2004 10:57 AM
