| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
I have to do move that is new to me. It is a helical interpolation. I'm not positive on how to do this. Tool diameter: 4.0mm Finished hole diameter:5.01mm LOC: 19.0mm I need to do a full circle arc and go down 19.0mm total. Any help would be appreciated. Thanks. |
| This is one way... (NORMAL START UP STUFF - PROGRAM IN MM) ... ... N40 G00 G54 G90 X0. Y0. S6000 M03 (POSITION TO CENTER) N50G43 Z2.0 H01 (RAPID Z TO CLEAR) (ENTER TOOL RADIUS IN D01) N60 G01 G41 G91 X2.505 Z0 D01 F100.0 M08 (FEED TO START) N70 M98 P102001 (CALL SUB 2001 10 TIMES) N80 I-2.505 (ONCE AROUND AT BOTTOM) N90 G01 G40 X-2.505 (CANCEL COMP) N100 G00 G90 Z2.0 M05 (RETRACT Z TO CLEAR) (ADDITIONAL HOLES) N110 G91 G28 Y0 Z0 (Y AND Z TO HOME) N120 G90 M30 O2001 (HELICAL SUB) G03 I-2.505 Z-1.9 (ONCE AROUND AND DOWN) M99 For additional holes, position X & Y, & copy N60 to N100 for each hole. If you do a lot of this, it might be worthwhile to write a macro, but that's another subject. |
| After reading your post i'm wondering if this is what i need? I am using a 4.0mm endmill w/.3 radius. I will be going in a predrilled hole and bore it out to a finished size of 5.008mm. I would like to make one continuous feed motion, circular and in z axis. After reaching bottom, i would like to go back to x0 y0 and rapid up. I have to do 16 of these holes in each part. Do you think i'm using the correct interpolation or should i try cylindrical, which i've never done either. |
| Helical Interpolation? Hmmm... that's exactly what I posted. Cylindrical interpolation wraps toolpath around a cylinder (engrave text on the OD of a shaft, for example). Try the example I posted; if it doesn't do what you want, let me know. Your original post said 5.01MM dia., this one is 5.008... you'll have to add to the value in D01 to adjust. |
| dcouper I have a Daewoo DVC320 mill with fanuc oi 21 controls. In your post you stated to put the tool radius in D01. I have never seen a D code nor can I find any reference to one in the book. Am I overlooking something? |
| wevz, G41 (and G42) offset the programmed tool path left (or right) of the path. To do so they need an offset value, which is stored in the control's offset memory. Most newer Fanuc's allow you to enter both a length offset and a diameter offset, but some don't. Look at your offset display: You may see OFFSET, SETING, and WORK. If you press OFFSET, you may see several columns: NO. GEOM(H) WEAR(H) GEOM(D) WEAR(D) 001 10.000 0.000 0.000 0.000 002 –1.000 0.000 0.000 0.000 003 0.000 0.000 0.000 0.000 004 20.000 0.000 0.000 0.000 005 0.000 0.000 0.000 0.000 006 0.000 0.000 0.000 0.000 007 0.000 0.000 0.000 0.000 008 0.000 0.000 0.000 0.000 For the example I gave earlier, your tool length offset goes in GEOM(H) #01, enter the radius of your cutter in GEOM(D) #001 Hope this helps. Dave |
| Cylindrical interpolation | davisboys | Fanuc | 7 | 01-01-2009 08:46 AM |
| How do you use polar interpolation | positiverake | G-Code Programing | 5 | 12-07-2006 08:59 PM |
| Nano Interpolation vs 104/D | TDavid | Fadal | 7 | 03-30-2006 05:36 PM |
| involute interpolation | utengineer04 | G-Code Programing | 0 | 04-26-2005 12:17 PM |
| interpolation | rimcanyon | General Electronics Discussion | 9 | 04-08-2004 01:10 AM |
