| Daewoo/Doosan Discuss Daewoo/Doosan machines here! |
Well we just got our Puma 240B/FANUC CNTRL in a couple days ago and so far I am pretty happy with its overall function. I am trying to tap (3/8-16) a hole down the center of my first part. I have the spindle at 400RPM and Feed at .0625 IPR. My code was as follows ... M3 S400 G01 X0. Z1.0 G99 G84 R.4 Z-1.0 F.0625 G80 ... and what the result was is that the turret moved to X0. Z1.0 then WENT BACKWARDS by ~.4"(im guessing) AWAY FROM THE PART. THEN TAPPED THE HOLE AND CAME OUT. I was anticipating the R plane to be .4 away from the part. From further testing it seems that the R is an incremental value and that is why it moved away instead of to .4 away from the Z0. work offset. So i could correct the code to R-.6 to achieve the desired result. Can someone confirm or point me to where in the docs this is an incremental value? I am coming from Hass mills and G codes are quite different. Thanks, GH |
| From the Fanuc 16/18/21i-T manual: G84 X(U)_ C(H)_ Z(W)_ R_ P_ F_ K_ M_ ; or G88 Z(W)_ C(H)_ X(U)_ R_ P_ F_ K_ M_ ; X_ C_ or Z_ C_ : Hole position data Z_ or X_ : The distance from point R to the bottom of R_ : The distance from the initial level to point R level P_ : Dwell time at the bottom of a hole F_ : Cutting feedrate K_ : Number of repeats (When it is needed.) M_ : M code for C–axis clamp (when it is needed.) |
| Puma 560 Robot | puma560 | RC Robotics & Autonomous Robots | 13 | 01-26-2010 07:02 AM |
| Puma & Procomm | ademir | Daewoo/Doosan | 4 | 11-28-2006 01:57 PM |
| Puma 6s parameters | sting | Daewoo/Doosan | 3 | 06-10-2006 06:29 PM |
| Post for Puma 8S | phoodieman | Daewoo/Doosan | 2 | 03-27-2006 04:57 PM |
| Puma 450 with fanuc 18t | The Puma Man | Daewoo/Doosan | 3 | 01-24-2006 09:54 AM |
