Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 03-19-2007, 03:35 PM
burnin daylight is on a distinguished road
tailstock won't extend
We have a daewoo puma 12L with a fanuc otb control. A couple weeks ago I had to dump the parameters and reinstall cause of shutdown while sending programs from pc. Everything seemed to be working as it was, but today I tried to use the tailstock and the center wouldn't extend. It's not programmable, has the pedal for extending and retracting. Diag. parameter 302 I think has something to do with it I set 0, 1, and 4 bit to 1 with no success. Also what parameter switches the control to read neg when going towards the chuck to work shift zero. Thanks for the help.
Right pressure for tailstock jani General Metalwork Discussion 12 03-05-2007 10:45 AM
tailstock (mis)alignment ajbarrell Shopmaster/Shoptask 8 01-06-2007 10:18 PM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 05:20 PM
power tailstock Runner4404spd Mini Lathe 5 08-28-2006 07:27 AM
Trim and extend? tinman13 BobCad-Cam 8 03-30-2006 10:11 AM
