Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Daewoo/Doosan
Daewoo/Doosan Discuss Daewoo/Doosan machines here!
Old 01-30-2007, 01:16 PM
M-man is on a distinguished road
Mirror image C-axis.
I guess Mirror image for x axis are used for dubbel turret lathes, but if I set mirror image for c-axis (Offset/settings page down). would this make it able to produces both a left and right version of a flange with the same program??
Old 02-01-2007, 03:14 PM
Hmm, nothing happen, the part were machined as programmed and no mirroring were taking place.too bad.
Old 02-06-2007, 04:00 AM
cincron is on a distinguished road
Hmmm... I never used that... It is just as easy to copy the program and changed your Z-Axis sign (if you're talkin the main is Z- and the sub is Z+) If you are using G2/G3, then just change those to to oposite also.
You could also use this part of th e program as a sub program with macro variables... loading it with a G65 P(sub program #) and take care of it that way too...
~Tony~
{Process Engineer, Lead Machinist, Supervisor, Computer Enthusiast, Linux & M$ User}
Old 02-06-2007, 12:35 PM
I was trying to cut a flange in axis C and just using one prg to cut a left and right version of part...
Fanuc 3T with no G68 X mirror Axxtion Fanuc 3 09-24-2008 10:21 AM
How can I reverse/mirror cuts? jtrimmer Solidworks 2 12-08-2006 11:44 PM
Mirror macro goodfella Coding 1 11-29-2006 07:38 AM
Need G68 mirror code for 3T Axxtion G-Code Programing 3 08-31-2005 10:46 PM
Mirror thickness CNCadmin Laser Engraving & Cutting Machines 8 08-04-2005 03:32 PM
